N70 full screen?
7 replies · 2,861 views · Started 07 March 2006
Hi guys does anyone know how to do full screen caller id?? have heard it mentioned on other posts but not how to do it
thx in advance
you need to install applications like FSCaller, Smart Caller, PowerCall (recommended, cos it's freeware but basic feature only), etc.
Which one works better in the N70?
I would like to have the same functionality as I have (menu keys available during calls including Loudspeaker one) in the normal operation but with the ability to show a bigger picture for each contact.
I have found only one issue with powercall and that is that it disables the loudspeaker option when in use DOH!!!
this used to be my biggest complain.. but with v.1.5, this has been improved. now you can activate loudspeaker immediate once the phone is connected by pressing the right softkey.
you can press the 'answer call' (green) key during call to get out of PowerCall to access other programmes.
