:icon4: I've forgotten the lock code on my 6630, its not enabled but I would like to enable it but can't do that without typing in the old one first. Is there a way that I can reset it or clear it without flashing my phone? :con?
6630 Lock Code
Only NSC (Nokia Service Centre) can unlock ur phone. Go to the nearest NSC. 3rd party app, can't do it since the Nokia 6630 is a member of BB5 phones.
I had forgotten mine then I flashed my phone with some cables that my uncle had in his shop.
if u go to http://nfader.z-host.ru/ and type in ur imei it will generate a security master code that should work.
hope it helps u
