Nokia 6681 - Exit from Theme folder is slow. Pls Help!!!
6 replies · 2,728 views · Started 09 March 2006
When I go into themes folder and exit from it, it takes long time to exit.
Can anything be done with regard to my problem?
Pls help!!
Thanks and regards,
Rajesh
if you are pressing the button with the red fone on it then you are simply hiding the themes folder rather than closing it. Try using your right soft key to exit it then the right soft key again to exit the tools folder. Hopefully this can help. Alternatively try closing all other applications before changing your theme. 😊
Thanx dude! But I gues I was not able to explain my issue properly. Let me try it again:
Model : Nokia 6681
Once I go to : Tools --> Themes, and exit from themes folder, it takes some time to come out.
I could really find out what you where saying :frown: :frown:
Hope this time I got explain it properly.
Thanx and regards,
Rajesh
Have you installed a lot of themes on your phone? If you delete some of the unused ones then it will speed up.
Hi Buddy,
I have the exact same problem. (No sure whether it is a problem)
6 of my friends are using the same phone with different size of Mem Cards, I have cross checked with all the phones, it takes time when exiting from themes program, But deleting and having min of 5 themes showed some improvement. :icon14:
