Does anyone know what my problem might be?? i got a dongle today v.2, 100m range all the specs i have heard are required, now nokia pc suite is not doing anything i am trying to connect but no flashing lights and worst of all no connection please help if i dont get it sorted my wife will laugh and tell me "i told you so" again as things very rarely just go the way i want them too so vv big thx in advance
pc suite and b/tooth connecting
I hope you have installed PC Suite 6.7 from www.nokia.com/pcsuite.
Go to winfows tray and right click on the phone icon, select about PC Suite and "system info" and tell what it says. If it does not list a bluetooth stack(sw), you don't have supported Bluetooth solution in your PC
I have 6.70.22 installed it also says it has stacking as well, have uninstalled and re-installed everything once only ) and no difference, have found how to use the obex and stuff for transfer but prefer the simplicity of pc suite so if any help is out there wpuld be greatful TIA
