Dear all,
We are getting error while installing the SIS file on Nokia 9300 it says:
Program Closed
Program: Installer
Reason Code: USER
Reason Number: 22
Anyone has any idea why this comes?
Thanks and Regards
Rajiv
Dear all,
Program Closed
Program: Installer
Reason Code: USER
Reason Number: 22
Thanks and Regards
Rajiv
terajiv wrote:Dear all,
Program Closed
Program: Installer
Reason Code: USER
Reason Number: 22Anyone has any idea why this comes?
Thanks and Regards
Rajiv
Er... *which* SIS file? And have you tried restarting the phone (battery out)?
Steve Litchfield
Hello Steve,
Thanks for the response, the application is Series 80 application, it was giving Reason Number: 22 but now its giving Reason Number: 7 Installation is perfect but when starting the application it gives Reason Number: 7
Do you know where I can get the details of these reason Numbers or how to overcome this error?
Thanks and regards
Rajiv
terajiv wrote:Hello Steve,
Thanks and regards
Rajiv
Err... you didn't answer EITHER of my questions!
Exactly which app are you trying to run and have you tried rebooting?
Steve
Hello Steve,
we have developed a custom application on series 80, myApp.SIS developed using C++.
I have switched of the mobile, taken out the battery and started again!
am I correct in the process of re-booting?
When you ask "*which* SIS file" do you mean the file names or technologies used?
am I correct in the process of re-booting?When you ask "*which* SIS file" do you mean the file names or technologies used?
Ah. Sounds more like you've done something wrong in building your SIS file. I assume other SIS files from the Web install OK? I think you'll need to seek C++ help over on Forum Nokia. This isn't really the right place!
Cheers
Steve
Thanks steve,
I will have a look at Nokia Forum
Thanks and Regards
Rajiv
