new 256Mb sandisk mmc card not 'seen' by my 6630
3 replies · 2,054 views · Started 11 March 2006
hi
I wanted to extend my memory and bought a mmc card of 256Mb. First I copied (thorugh my card reader and pc) the content of the original 64 Mb card onto the new card. Then I placed it in the phone. The phone doesn't see it, gives message like 'place memory card' while mmc is in and lid is closed. It does see my orginal card when i place it back. Than I removed all files from the new card and trijed again - no success. Than I compared the filesystems of the 2 cards: both are FAT. I reformatted on the pc the new card using FAT (not FAT32). After all this the phone still doesn't see that i insert the mmc card.
Anybody can help?
Thanks in advance! 😉
Albert
My guess: Your SanDisk card is a "regular" RS-MMC. It won't work in the 6630, because the 6630 needs a Dual-Voltage (DV) RS-MMC (or MMCmobile) card.
"Regular" RS-MMC cards operate only at ~3V (Volts).
Dual-Voltage cards supports also (besides ~3V) operations at ~1.8V, which is what the 6630 requires (uses less power, too).
MMCmobile cards are DV RS-MMC size cards with extra pins and support for higher speeds (which the 6630 can't take advantage of, but the cards will still work).
thanks for your message N/A
I bought the card as a 'card ready for mobile phone' - that is what it said on the pack. However, on the card itself is written only 'RS-MMC' it doesn't mention 'DV'.
On my original Nokia card 1.8V-3V is written. So probably you are right - the card is suitable for phones maybe - but not for mine ...
The 'User Guide' book (came with 6630 box), has the explanation regarding to 6630 MMC. Or more better if u consult to nearest NSC (Nokia Service Centre) 😉
