N6680 movies
3 replies · 2,502 views · Started 11 March 2006
hello all.
im just wondering if anyone could suggest some FREE software to convert and compress DVDs in order to watch them on my N6680? i converted some music viseos from my pc using the software on the nok pc suite supplied with the phone but the sound is real bad and the picture hard to mae out. I have seen some software on the internet but these are expensive.
i posted this on the 6680/6630 general forum earlier but realise this was probably a better place to come. :icon14:
Use smart movie converter which will compress the videos and convert them into .avi format.
After that you can either use dvd player or smart movie player to view them.
You pay for smartmovie converter.....you other option is TCMP The Core Media player for series 60....try that....windows media converter will convert any file to .wmv both are free.
-@dam
Not sure whether or not u understood my question. i want to convert DVDs to a smaller format so that i am able to watch them on my phone not the other way around thanks. + i would sumthin free if there is- scobe i no! lol :icon14:
Cheers
