I used to use ReadM on a Sendo X before Sendo went under and the phone started playing up and found it to be an excellent reader app. I have installed (and uninstalled) it on my 6680 a number of times, and I don't find the installation to be stable - it loses its extra components and options like full screen, and can only be run from a file manager. The author's website has been taken over by someone else. Does anybody have similar experiences? If so, have they found a cure?
ReadM problem
Hi, this might help you:
If ReadM crashes halfway through reading a file, the Page Code may be set incorrectly. Make sure that "Code Page" is set to "Windows-1252"
Also, try installing it on the phone then on the memory card, it may work better on one or the other. I have it installed on the memory card.
Jamil.
