MMC Nokia 3230
2 replies · 2,130 views · Started 12 March 2006
Hi All,
Can Anybody Help Me In Recovering The Password Or Removing Password (if Possible) Of My Memory Card For Nokia 3230? Please List Each & Every Option That You Know.
Chill,
Bye.
This is has been discusse so many times. Use search feature. Find an app called mmcpwd or get it here
Or, for the fastest way, format ur MMC using N9210 or digital camera. But u'll loose al of ur MMC data.
Instal FExplorer from http://www.gosymbian.com then go to C:\System and find the file mmcstore. Send it to computer or view it with Hex/text viewer. The last characters are your password. Install FExplorer in the phone memory, so you won't have nasty surprises.
