Icon Manager Released!
13 replies · 5,576 views · Started 21 November 2002
Ever get tired of replacing iconpacks on your 92x0 just to test some other one? Ever had to copy and replace iconpacks just to be able to change that one litlle icon on desk? Nevermore said the raven ... and right he was 😊
With IconManager you'll be able to load up to 198 iconpacks! Without ever replacing any of your favourite ones you'll be able to load and test all sorts of iconpacks to give your applications on desk that little extra touch 😊
The iconpacks can be stored on either C or D. When a iconpack is loaded the icons will become available for
you to use for you shortcuts in Desk!
To help promote this app I've created 5 new Iconpacks for all your icon needs 😊
I even have some skins to go along with them 😉
Check them here
This application is total freeware, but if you nevertheless feel the urge to do a good deed or if you just have money to spare;
It's for sale on Handago for a small price of $2.5 😊
Get it here 😊
pardon my ignorance, where should i place the .mbm files? particularly where in drive C or D? I tried placing it on system/data folder but the iconmanager wasnt able to locate it. Help, please.
Thanks.
apcaw, Basically you can place it almost anywhere. The Icon Manager will do the rest of it.. 😉
but i tried placing it in C, D drive, download, photogallery, system/data but still no luck. Where did you place yours?
Thanks.
Well apcaw, I just keep it in my D:/downloaded file. and when you run the icon manager it should be able to scan it. or else try the Menu, File, Select "load a iconpack". you should be able to get it from there.
Good luck
Great staff There !!!
Will install it and finally be able to personalize my desktop.
Thanks dazler for that app.
PS. By the way, I am trying to go to your link page, but it seems that I always have the same result...
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Any clues ???
😮nfire: filakia 😮nfire:
[quote="apcaw"]but i tried placing it in C, D drive, download, photogallery, system/data but still no luck. Where did you place yours?
Thanks.[/quote]
You'll have to load them using Icon Manager 😉
Now that Icon Manager has the icon packs loaded, how does one change the icons in your running system (9290)?
SoCal
Dazler, I guess I missed something. Please tell me what is that thing you call smart memory on your site. Is that an app, or is it something new... And of course, where can i get that app....
Thanks.
[quote="SoCal"]Now that Icon Manager has the icon packs loaded, how does one change the icons in your running system (9290)?
SoCal[/quote]
You can only change icons for shortcuts on your Desk.
In desk ctrl-p and you'll see the properties .. here you can use the new icons ...
[quote="samthepaokfan"]Dazler, I guess I missed something. Please tell me what is that thing you call smart memory on your site. Is that an app, or is it something new... And of course, where can i get that app....
Thanks.
😮nfire: filakia 😮nfire:[/quote]
Get it here 😉
