hi
When I set the mp3 ringtone "set as ringtone" , usually when the phone rings I hear the , nokia default ringtonr instead of what i had selected
so any way to solve
thnx
hi
so any way to solve
thnx
mihir880 wrote:hiWhen I set the mp3 ringtone "set as ringtone" , usually when the phone rings I hear the , nokia default ringtonr instead of what i had selected
so any way to solvethnx
Sounds like you need the N70 ringtone patch!
http://europe.nokia.com/nokia/0,8764,77767,00.html
thnx
I had already install that nokia patch , but still having the same problem
so wanted to know is there any thing u can suggest
mihir
I have also installed the nokia patch but can't set mp3 as ringtone😞 Only possible to change with midi-tones. If I set an mp3-tone I get the awful nokiatune. Please help quickly.....
Change your log duration from 30 days to 1 day.
Menu > Log > Options > Settings > Log duration
This will significantly reduce the number of times your phone defaults to the Nokia ringtone.
It's a well known bug of the N70.
S.
The patch doesnt help alone. Get a firmware upgrade and then apply the patch. It helped me from this issue which bugged me for a long time.
To check the firmware version type *#0000#.
You should have V 5.0609.2.0.1
01-03-06
RM-84
To know about other details of the upgrade check this out
http://www.allaboutsymbian.com/forum//forum/thread/45165/&page=5
Can anyone test this. It has worked for me without fail for more than a month now. If it does work we can get this stickied since a lot of people are asking for this.
