Hi This is the Cheapest BlueTooth USB connecter Ive seen so far.
has any body seen any cheaper or know the differences between em? :P
http://www.blueunplugged.com/shop/detail.asp?productGroupID=161&deptID=12
That is not cheap,cheap is 40$ for MSIs tranceiver key which i'm geting tomorow 😊
[quote="GhostDog"]That is not cheap,cheap is 40$ for MSIs tranceiver key which i'm geting tomorow 😊[/quote]
yup!! got an MSI too!! 😉
Yes, MSI key is cheap and it's communicating good with 7650
$40 ... I saw one on a US web site but they only ship within US.
Whats an MSI ? :roll:
got racewood usb bt from e-bay for �30, works fine with pc suite etc (although had to download new version of bluemanager to make it work properly)....
[quote="Darkst0rm"] $40 ... I saw one on a US web site but they only ship within US.
Whats an MSI ? :roll:[/quote]
MSI is http://www.msi.com.tw
check out ebay.co.uk
I got a bluetooth adapter working fine
for �28 .....I dont think there is so much
quality difference between them unless you
buy tdk or something
Thanks Ill give ebay a try!
Im curious about these MSI motherboards with Bluetooth built in..
I guess thats another option,.. seems like Bluetooth is really taking off
[quote="Reggie"]check out ebay.co.uk
buy tdk or something[/quote]
what's the difference between TDK and MSI bluetooth dongle? :roll:
[quote="Darkst0rm"]Hi This is the Cheapest BlueTooth USB connecter Ive seen so far.
http://www.blueunplugged.com/shop/detail.asp?productGroupID=161&deptID=12[/quote]
http://www.billionton.com/english/product/USBBT02-X.htm
I have that one its working terrific!!!!!!
90sin dollar in Singapore
I got two dongles from Dabs:
http://www.dabs.com/products/prod-search.asp?action=search&stab=ref&ob=manufacturer&cs=Home
�28.19 inc VAT They sell them very quickly. So, grab them while they are in stock.
The dongle works fine with the 7650, plus you can use an assortment of drivers. Either the ones that are shipped (XTNDConnect Blue Manager), or the Widcomm stack (which I use). Plus, it is also compatible with microsofts XP drivers (although you can't connect to the 7650 with them)
Excellent value for money.
Andy
[quote="Darkst0rm"]Thanks Ill give ebay a try!
I guess thats another option,.. seems like Bluetooth is really taking off [/quote]
I'm not sure, that integrated BT is something super. That isn't integrated transceiver, at MB are just connectors and you need to buy BT device which you must plug to this connectors. This device cost as much as USB key and you can't use it as easy as key. So I think that USB key is better.
zail
Posted: Thu Nov 21, 2002 11:35 pm Post subject:
I have the same, do you find the Blue manager (V2) very stable? I keep getting GPF's in XCBLUMGR. I am on Win98 (V2) and have tried on 2 different PC's (the second a clean install).
Have you noticed that if you move the phone out of range and then come back that the Blue manager finds the phone but Nokia Connection manager doesn't? I usually have to click the com port tick off then on again.
Please let me know if you find the same as all I want is the phone to sync to Outlook everytime it is within range and not spend ages rebooting the PC and playing with it!!!!!!!!!!
I've spoken to Nokia and they say it is a Blue Manager (V2) problem and you guessed it, I've mailed the bluemanager people and they say it is Nokia PC Suite (V1.1.0). I reckon Blue manager!
Cheers
markb
I am a regular see previous post!!!!!
[quote="Mark"]Have you noticed that if you move the phone out of range and then come back that the Blue manager finds the phone but Nokia Connection manager doesn't? I usually have to click the com port tick off then on again.
[/quote]
The same thing happens for me with the Widcomm stack. To reconnect the phone I have to open up the mRouter, and uncheck, then recheck a com port. Usually (though not always) a different one to the one that is used for the connection.
What would be better would be a way to connect the phone to the PC, rather than the other way around....
Andy
Thanks Reggie,
I just Won my first ebay auction ! �27 Bluetooth on its way !! :angel:
Bluemanager 2 doesn't seem that stable ... under win2k it prevented pc shutting down correctly. Using pc suite no problem although i have to check and uncheck the com port in the nokia manager when the phone has been out of range also.... haven't tried syncing to outlook - let me know how you get on.....
At last someone else is having similar problems with Bluemanager V2! I suspect that they still wont admit to there being a problem!
I can sync with Outlook (2000) fine when I can get it all hooked up! It syncs contacts, Calendar! & tasks, but notes wont sync, no option!!!!
Cheers
Markb
i shall e-mail them and let you know their response.... every time i shut down win 2k i get a btusrbdg not responding dialog box...
Following on from my previous post...
I purchased a USB Dongle - Racewood (BTD-2403) which uses Bluemanager (V2) - from eBay and have just received a mail from the supplier saying that there is definatley a problem with them or the software. I'll update when I hear more!!!!!!!!!!
Anyone else finding problems?
Cheers
markb
[quote="zail"]Bluemanager 2 doesn't seem that stable ... under win2k it prevented pc shutting down correctly. Using pc suite no problem although i have to check and uncheck the com port in the nokia manager when the phone has been out of range also.... haven't tried syncing to outlook - let me know how you get on.....[/quote]
I just got Racewood with Bluemanger 1.8 , Nokia Suite or Mrouter doenst seem to detect my phone. .. didnt think BlueTooth was gonna be so fiddley ,, have spent hours on the web searching to get it to work 😞
i have that dlink usb adaptor in ur link.
i highly recommend it, it's really small (the same size as a usb plug) and everything works for me, including pc suit for windows xp.
😮ops: OK Before you read this I'm sorry!!!!!!! 😮ops: I've put off post this for too long!
But......I am still having problems with Bluemanager V2 and Nokia PC Suite 1.1.0!!!!!!!
Getting GPF's etc. and the rest of the problems posted previously.
I have tried a dongle from Dabs.com ( wavelinker) and previously one from Racewood. I have installed Win 98SE, any number of times, on different PC's (clean basic installs with different copies on 98se) and still getting GPF's in XCBLUMGR. My last idea is to download the lasted updates for Win98se, from microsoft, in the insane hope it may help...so I may be gone for some time! :cry:
Please can some one put me straight, as if I do not get it working soon I'm going back to my Nokia 5.1!!!!!!!!!!!!!! :cry:
(PS please don't suggest moving to win2000 etc)
Cheers
Markb
Try the WIDCOMM SOFTWARE instead of the BLUE!
*eagerly awaiting dlink bt-usb adapter arriving next week* had major probs with IR so this should be a whole lot better 😊 - cost approx US$50 or UKP$33
MaleBuffy Posted: Mon Jan 06, 2003 9:55 pm Post subject:--------------------------------------------------------------------------------
Before you say it I have spent a couple of hours searching through the forum, looking for the latest Widcomm software to download. I have found this site
http://www.tecomproduct.com/asp/support.asp?Navi=SoftwareDownload and download BTW12216.zip
but only 2.5Mb (it says it is 16Mb) downloads and then the file wont unpack.
Please, can some one suggest another location/file? and what the latest version is.
Thanks in advance
markb
