App that will view .txt or .doc files?
4 replies · 2,232 views · Started 14 March 2006
Is anyone aware of a Symbian freeware app that will allow the viewing of simple .txt files (like lists) or .doc files.
I want to type out grocer lists then bluetooth them over to my notes section of my 6620. Right now, the only thing I can think of is emailing to myself so smsing myself. Hard to organize though.
Suggestions?
Thanks,
Tmuld.
AFAIK, it's work with N6600 (OS7), N3230 (OS7) and of course with N6630. Just try or contact Nokia 😉
Yes Quickoffice works fine on the 6620. You might also want to check out OfficeSuite from MobiSystems
