Forgotten my wallet code, can you help!
11 replies · 16,503 views · Started 14 March 2006
I have Nokia 6600 and now have forgotten my Wallet code. Can you help me in retrieing the same or resetting a new one.
Preeti
I also forget wallet password like Preeti. Pls help me.
I also search in nokia site.
Preeti if u get how to recover password then pls post the method here.
-----Brain Bond:icon14:
As I said, the wallet reset code is printed/documented in the phone's User's Guide. Locate it there. If you have lost the guide, you can find it on nokia.com in the phone support area.
Recovering the wallet code/password is not possible.
to reset the Wallet to factory default, just press this code as follows:
*#res0wallet#
This will factory reset the wallet, and you will have to give it another code. Please type the code in while on the stand by screen.
p.s. Other resets:
Normal Reset (*#7780#) : Restores ini files from rom but preserves user data (photos, 3rd party apps etc)
Deep Reset (*#7370#) : This reformats completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten.
Is there an application that will take the place of our wallet? At least, we can doing a backup for its content.
[I have a 6630 and my wallet password is blocked.. please help me out in resetting the password..
Sajan
Perhaps you could consider reading earlier posts in this thread (or at least the phone's User's Guide where the wallet reset code is documented)?
preetijoshi wrote:I have Nokia 6600 and now have forgotten my Wallet code. Can you help me in retrieing the same or resetting a new one.
Preeti
hello type the *#7370925538# at the main screen if it asks for a password type 12345 this should work
brain_bond wrote:I also forget wallet password like Preeti. Pls help me.
I have Nokia 6630 and now have forgotten my Wallet code. Can you help me in retrieing the same or resetting a new one.
touchdamu wrote:I have Nokia 6630 and now have forgotten my Wallet code. Can you help me in retrieing the same or resetting a new one.
Read the earlier replies. The answer is there (several times, as a matter of fact).
