Why, OH Why, can't i get tomtom mobile 5 to install on my 9500?? did exactly as requested, copied all the files to the MMC selected the installation file only to be told that "object cannot be found" sounds like software problem, a corrupt file somewhere?
ttfn
jt2k6 wrote:Why, OH Why, can't i get tomtom mobile 5 to install on my 9500?? did exactly as requested, copied all the files to the MMC selected the installation file only to be told that "object cannot be found" sounds like software problem, a corrupt file somewhere?ttfn
Hmm... I thought TTM5 *came* on an MMC? Where did you buy it from?
Steve Litchfield
Try to set the settings of your files to show all files and then copy all files to the right directory
