Untrusted Certificates
2 replies · 4,536 views · Started 14 March 2006
I'm using my 6682 to check Gmail, which it has no problem doing. However, each time I have it connect to check the mail, it says that the site has an untrusted certificate, and requires me to confirm the connection. Is there a way to add the certificate to some sort of trusted list?
That's fantastic, thank you, but once you have all these .cer files what folder, on the phone, do they go into? and which ones do i install?
