Sendo X losing it...
9 replies · 4,458 views · Started 14 March 2006
...And me too...:frown: Lately my Sendo is really acting weird. After reflashing it (again!) I'm getting the same bugs back. They are:
[LIST=1]
[*]Not receiving phonecalls when having full reception and a full battery;
[*]Lately not even receiving sms when phone is fully charged and having full reception;
[*]@ random switching on and off while making a phonecall or just being standby
[/LIST]
The first problem is solved after switching it off and on again but I never know when this happens because no one can reach me!
So after flashing I got the second bug, sms's not coming in at all. Also completely @ random.
And there's the swithing off and on bug. This really annoyes the crap out of me!!!
I'm afraid there's nothing I can do about it, but I hope someone has some sort of brilliant solution to this...Right now I just want a phone that works, I don't even care about the (not so) smart part of it.
Now I know someone already asked this in another thread, but is it possible to copy my contacts to the sim? I can't sync it with outlook or lotus or whatever cause my pc doesn't see my Sendo anymore. A few weeks ago it did work. but after the new bugs coming, I can't sync anymore. So I'm looking for a third party app. to copy contacts to my sim. (Synchronising really doesn't work anymore, already tried newest pc-connect s/w and mrouter, it looks like my Sendo got some permanent damage or so, I don't know...what I do know is that I'm getting a new phone. No fragile smartphone crap for me, but maybe something like a solid 3310 😉 )
It seems to be a hardware problem.
Probably, if you use the sendo like me, you have to clean all the contacts.
I always keep it really clean (I use a piece of cotton with alcohol) and my X it's still on the road!
1. For the sync problem you can try to clean the connector;
2. for the reset problem clean the battery;
3. for the calls/sms recieving clean the sim (use a white rubber).
Does sound like a contacts (dirty ones) issue. I've never seen a phone do what you're describing. I *would* recommend a reformat, but I know you know how to do that.
Otherwise, I can't think of agood reason why you should be seeing what you are...
Well, I tried Ermete's suggestions. At the moment no funny reactions from my X, so I'm hoping it'll stay like this. The switching off and on bug is really weird. What happens is that it totally @ random switches off, screen turns white, then red and then it boots. R-e-a-l-l-y weird...
stuclark wrote:Does sound like a contacts (dirty ones) issue. I've never seen a phone do what you're describing. I *would* recommend a reformat, but I know you know how to do that...
Yeah, I'm starting to get the hang of this...😉
Sigh...It happened again...:frown: I was making a phonecall and it suddenly frooze and rebooted. So, I'm still 6 months stuck to my current carrier and thus 6 months stuck to my f*cked *p X before I can upgrade. This really sucks...
Am I the only one here having this problem?
in the last week my x has developed a problem. it can no longer send texts! i havnt gotta clue why it isnt working. any suggestions? and before you ask i do have credit🙄
Sounds strange, never heard of this before. How much free ram do you have left? Maybe installed too much apps or txt's or...? Maybe you could try formatting your X?
Btw, what do you mean by
...before you ask i do have credit🙄
turned out the settings had somehow changed from o2 to sim or something. i meant calltime by 'credit'
Well, I've frikkin had it with this handset!!!😡 I'm going back to my good old panasonic gd92 for now and will upgrade when I'll be able to renew my contract.
Thnx for all the support guys.:icon14:
