I have installed psiloc screen saver v.1.21 onto my n70 but it crashes when i try and use it, when i go to remove it, it says "removing Failed!" then "Installer: Feature not supported"
I have tried overwriting it with the newest version 3.06 but that gives the same error.
Id be happy to either get it working or get rid of it but i dont want it there if it isnt working and dont want to format.
Thanx, Leigh
