Software to send SMS from N70 via Computer ???
6 replies · 4,395 views · Started 15 March 2006
Hi All,
just wondered if anyone knew of any software that you can use to access and then send SMS / Text Messages from computer via N70...???
My previous phone was a 6230 and I was running some brilliant software called Phone Director by MacMedia which amongst everything else was one thing you could do.
By the way I'm on a Mac not a PC so I guess that narrows down the field rather a lot but as a Designer who is in front of a G5 for 10hrs+ each day being able to compose, send and receive text into the comp via my N70 would make life much easier.
Thanks in advance for any help.
Nick
rulirahm wrote:I'm often to use that and a good feature from Nokia PC Suite 😉
Nokia PC Suite is only compatible with Windows PC not Mac OS X - no worries anyhow guys as I have found a great little program for the Mac called GSM REMOTE which does just what I need.
Any other Mac users who need to send SMS from their Mac via N70 click here:http://www.traud.de/gsm/remote/
sky3 wrote:Nokia's PC Suite allows youto send through your PC!
i tried that & it ddint work. any clues on to why?
btw using cable connection
