Anyone using Nokia sensor in N70?
5 replies · 4,863 views · Started 17 March 2006
Hi all,
I'd like to know if someone is using the Nokia sensor (BT chat) in its N70. In the list of compatible phones for that SW in the nokia webiste the N70 is not included. I'd like to avoid problems if I install and it doesn't work.
The version on the website does not work on the N70. Hopefully there'll be an update that does.
N/A wrote:The version on the website does not work on the N70. Hopefully there'll be an update that does.
Thanks. Let's wait for the new version
the version of the 6680 works on the N70 but it works for 90%.
And it isn't because of my phone. A friend of mine has an N70 too and has the same problems. The sensor chrashes when scanning for profiles. The rest of the app works good
You can try mobiluck.com as an alternative which I believe does work on the Nokia N70.
