N70 - Can I Clean Out Application Manager Once Installed?
3 replies · 4,817 views · Started 19 March 2006
Have just got an N70 on O2 now after all the problems I had with my Orange N70. Very pleased with it indeed, much, much better.
There seems to be loads of extras on the MMC showing in application manager. When viewing the details for each app it states as installed, so does this mean I can now remove from memory? I like to keep my device as clean and uncluttered as possible so anything I can remove would be good.
Any guidance or comments would be appreciated.
Many thanks
You can use the App. Manager to uninstall (remove) those installed apps you don't use.
Thanks again N/A. I had a load of Apps on the O2 MMC but I've formatted the card and lost them all now :frown:
Not sure if I needed the Apps or not but would have been nice to have the choice. Is there any chance of me recovering the files and getting them back on the MMC?
I could do with a new O2 MMC from an N70 really, I could copy the files to my computer so I always have a back up just in case.
U can recovering deleted data on MMC by using FileRecovery for MultiMedia but I aint sure it'll get back as before...
If the app came with Orange, then maybe by contact them again to get the app? If came from Nokia, then u can browse Nokia site for N70 about Support app for owner.
