nokia 3620
1 replies · 1,574 views · Started 20 March 2006
I have a nokia 3620 and my litte brother put the wrong mmc card in it . now i can access alot of thing with errors and some without . I have pc suite but im not shure if that will help (i never made a backup copy ) what can i do
Remove the MMC and use the odl one. It shouldn't have done anything unless he installed something or you no longer have data on the old card (in which case you might be a bit stuck - you might need to uninstall / reinstall everything).
