My Operator Logo Shows And Then Dissapear Back To Orange Logo!
I Have Firmware Versoin 3.12
Maybe Anyone Have Any Ideas!???
You should scan thru the forum. You will find the result.
Trust Me I Search All Over The Board And Can't Find A Thing
I Changed My Operator Logo I Can See A New One Colored But Only For 2 Second! And Then It Dissapears!! What Should I Do?
Whatever the reason is.. you cannot change your logo..just like I.
It's on the simcard or something ..so it's not changeble.
Im on Vodafone in holland and i cannot change it.... 😞
The Problem is the sim card ~
cos ur operator insert logo to ur sim card ~
if u dont belive u use a old sim card u can have the logo back ~
Nothing i can help ~
maybe u can get a sim reader and delete the logo in ur sim card ~
i have the same problem. bugs me that i can't get the op logo i want. sigh.
Anyone Have Any Ideas?
[quote="DjYos"]Anyone Have Any Ideas?[/quote]
how do you go about changing it??? i believe some filemanagers (the initial and earlier versions) have this problem. u might be using an older filemanger. the easiest and simplest way to do it is with SeleQ.
a new version just came out - 1.5i
check this site and download the trial! im sure after doing so you will buy it!
www.ximplify.com
The operator logo is hardcoded on the sim,so there is no way that you can changed it,or maybe there is,but i'm not avare of one.
