problem with loopset and headset
0 replies · 1,480 views · Started 23 March 2006
hi everyone ...
i recently bought a 7710 it was working okay .. but some times when i recieve calls or try to call someone i dont hear any thing so i have to activate the loud speaker to listen then deactivate it .. some times it solve the problem and i be able to listen form the normal speaker and sometimes don't.. i tried all the things in the enhancment option for the loopset and headset.. some times it works and others dont atall.... can anyone help me
other problem ... when i try to edit or add a contact it keeps retrieving like for ever..one time i left it for over an hour and it didn't finish, it also hangs the phone i was unable even to turn it off.. i had to remove the battery.. i tried another sim card... same problem.. can any one tell me what to do
thanx guys for reading... hope someone knows the solution:con?
