I have nokia n70 and I would like to install satnav.
I download tomtom mobile5 and route 66 mobile 7, both are in app/rsc files.
when I put the file on the phone its not recognze it.
can I convert or there is a way to install it?
thanks
thanks
If you buy the apps properly, you will get proper installation files (or the apps presinstalled on a memory card). Note that you'll also need a Bluetooth GPS unit (the software alone is not enough).
