hi there,
i have tried installing the .sis files of known software that are compatible with the N70, such as Smartmovie 2.76 and smart Comgps-S60, but when i try to install the software i get an error on my phone saying "Installation security error. Unable to Install".
if anyone happens to know why this is happening then please help.
thanks
Having problems runing software that work on Nokia N70
tools>manager>options>settings>software instaltion= on
soft will now install
p.s. mods this should be a sticky since is a FAQ
wow fanx man!
i went into application manager and i put install on.
it works.. the files install.
thank heeps!!
hello again,
ive got another problem but this time it involves using applications such as e-messenger over the web on the N70. when i go on www.e-messenger.net to use the messenger client for mobile, it works fine, but once i log in and click on one of the members on my list to chat, the web application closes all of a sudden, and brings me back to the main screen. all other websites and most other operations on the web work fine. but how and why does the web application close when i try to open a chat conversation on e-messenger. are there any settings for my internet or security or applications that need to be changed? can i fix this any other way through the phone.
please help. fanx
www.e-messenger.net is deisged for the desktop sicne it uses pop ups. the web application cant use these
use wap.e-messenger.net or www.e-messenger.net/mobile (i think the last one is correct aswel:con) & e-messenger will work fine
hey thanks for resolving that last problem of mine. you are extremely helpful.
but now it seems im stuck with another problem.
when i use to have my 6600 i installed and cracked the smartmovie player and converter with no prob. but now when i try to follow the same instructions with the smartmovie zip folders, as i try to overight the smartmovie.app (crack) file into the system folder of my N70. the smartmovie application doesnt even work after i do what it says to.
so i am stuck.
is it still possible to use the same version of smartmovie for S60 on N70 and still have it unlocked and working?. or do i have to find another or better copy of a cracked smartmovie zip file?
Here's a useful link for you (all you need to read is the first few sentences, and all becomes clear).
ok thankz now i understood. i need to register. lol
well if you cant get that one, i got something else you can help me with.
how do you remove the operator screensaver and replace it with one of your own.my N70 is a vodafone live one, and it has the stupid voda screensaver that i want to get rid of.. im sure there is a way to do so.. please help..
thankz
