I've got a big unistallation issue.
3 replies · 1,168 views · Started 24 March 2006
I just bought my N70. It came with 3 Pre-Installed games -
1. Card Deck
2. Snowboard 3D
3. Snakes
NOW, all of them DO NOT show up on the app manager so i can't un-install them form there. Now i install Fexplorer, from there i go to C, system apps, i see NO directory related to those games!
Exept there this directory named - " [10181ddd] " and it has these files in its directory -
[10181ddd].aif
[10181ddd].app
[10181ddd].bin
[10181ddd].txt
I deleted them, then i tried to open Snowboard 3d, the game didn't open.
I restart, open the game again and now it plays and when i check that deleted directors its BACK!!
Man, i'm tired, if there's a way to format the internal memory then please tell! Btw they don't even show up in the 'install' directory. So yeah this sucks.
Somebody please help! I wanna get them out of my new phone 😡
Or should i take this back to the place i bought this from and ask them to remove it for me to be on the safer side?
they are all built into the z drive of which yopu cannot delete or add or modify things in (ROM) so your stuck with them.should bother you 2 much put them ion a folder named games & thats it they are outta the way
Meh!! Anyways that's a good idea, i'll jst put them away in some directory and never open it again.
Anyways, thanks!
- Also instead of wasting another thread i'll just ask this other question i have here -
Is it safe to de-attach the N70 from the N70's side when i'm done transferring music throgh the suit??
yeah. if the conenction is disturbed when transfuring the files will only be half done & probs corrupted, but if its idle then its fine.
