Communicator browser incompatible with domino`s server
2 replies · 1,635 views · Started 24 March 2006
Hi to all!!
a lot time time ago, I have tried to access to my corporate E-mail from my N 9300 ( Opera browser ) , but without sucess
Why?
When I try to enter to the web page, it display me, is not possible to enter, your browser version has been detected as explorer 4.0, you need to update to onwards,
so, I have a question, is possible to update the opera/explore version?
any suggestion????
my second problem...
In other web page, BUT! developed in java, from my N 9300 all the up bar as well as some buttons are not visible, so what can i do??? exists a java platafform in symbian language for my N9300 like J2SE for PC???
thanks for any help...
NokNoki
Your phone's web browser isn't really that old (based on Opera 6), but the web site you're trying to access is proabably using features that it doesn't support, or they're just detecting the browser type and refusing you access without really knowing whether it'd work or not.
Anyway, the 9300 supports Java, but not J2SE. It supports J2ME and the Java Personal Profile. See http://java.sun.com/j2me for more details.
Web sites with embedded Java expect J2SE. Such Java applets on web pages won't run on your phone.
There is no separate/newer web browser to install on the 9300.
