Please Help Before I Buy A 9200
1 replies · 2,113 views · Started 25 March 2006
i want to get a nokia 9200 because it has black berry i currently have a pocket pc based smart phone and i can sync all my folders in my outlook 2003 to it i have called nokia and i can not get a stright answer from them re this what i want to do is sync all my inbox and folders to the 9200 via the cable and then use the black berry.
any help would be of great help!!
There is no 9200, but there are the old 9210, 9210i, 9210c and 9290.
Then there are the newer 9300, 9300i and 9500.
Only for the newer Communicators is Blackberry software available.
The local phone-to-PC synchronization doesn't support "all folders" (if you mean subfolders or other Contacts folders or email folders in Outlook). Only the main/topmost folder you choose will be synchronized with PC Suite (http://www.nokia.com/pcsuite).
