Removing app that won't remove ("running")
1 replies · 2,668 views · Started 25 March 2006
My Nokia 6682 (Cingular) won't let me remove the application I most recently installed (the bluetooth "freedom mini" keyboard driver from frekey.com). I suspect this application may be preventing the phone's browser from starting (the browser exits as soon as I start it.) I don't know if these are related but I'd like to remove the bluetooth keyboard driver and see if I can isolate the culprit affecting the browser (the 6682's native browser.) The error message indicates the application (the keyboard driver) is running, even when I turn the phone off then on again, without bluetooth enabled. If I can't remove the application, can the 6682 be restored back to default configuration (removing all installed apps) so I can start over and try to identify the conflict?
Thanks very much,
Dave
[email][email protected][/email]
you can try to start the phone in "safe mode". Just hold down the PEN key when starting the phone. In safe mode the phone will not start any applications and you can remove the program.
😊 good luck
The_LeadeR 😎
