problem with headset. help plz!!!
3 replies · 1,290 views · Started 27 March 2006
i have a 512mb MMC and i got plenty of mp3 on it. i use the HS-3 headset to listen to my mp3 but recently the right earphone doesn't work(no sound) while the left one is ok. the other day i connected my HS-2R to my 6630 and after that i connected my HS-3 and it began playning normally, ie with stereo sound(both earphone working). however after some time when i reconnect my HS-3 only the left side works, so wat could be the problem?? plz help me coz i use my 6630 as mp3 player
rulirahm wrote:Try another HS-3 headset. Maybe the problem because of the dev.
wats the dev??? now when i connect the headset(hs-3) it says sometimes says enhancement not supported and the music comes ferom the louadspeaker, or somettimes it says voice tags not saved and it plays normally, or sometiimes it says nothing and we can hear sounds only from the left side. anyone got same problems here???
Try to use another HS-3 to see which one is error. Ur phone or the HS-3 or take it to nearest NSC and let them try it 4u.
-Try run phone with safe mode
-Checkout installed apps
-Format phone/MMC.
More info:
http://www.allaboutsymbian.com/forum//forum/thread/44365/
