'Normal' Nokia Ring Tones For N70?
6 replies · 2,212 views · Started 29 March 2006
Hi, would like to get some standard Nokia ring tones for my N70. When I had my 7610 I had a couple of normal rings (high pitch & low pitch) and Bee etc. but I haven't got these on my N70, just a load of dodgy musical ones which I hate.
I have a Nokia 6230i too which has these standard ring tones on it but it will not let me send them (via bluetooth etc.) and I can't copy them to the memory card either as they all seem to be locked.
I have looked everywhere but can't seem to find them, even on Nokia's own website. If anyone could direct me to where they are I'd really appreciate it. :con?
Yes, I've already downloaded the patch but unfortunately it doesn't give you any more ringtones. I can't believe there are none on the N70, doesn't Nokia realise that not everyone wants dodgy tunes?
I ever try to change a ringtone between different phone model and what I got is the sound as not good from native phone.
steff2632 wrote:try using fexplorer to fidn the ring tone that you want & send it to your n70
Hi steff2632, I'm not quite sure what you mean. I have FExplorer on my N70 but don't think it has some standard Nokia ringtones on it though.
:con?
He mean that, use fexplorer to find the ringtones that u want on another phone (7610) and send it to ur N70.
