Q: Bluetooth Audio: Use phone as PC speaker - is this possible?
2 replies · 3,974 views · Started 29 March 2006
Obviously ppl normally use a Bluetooth headset in conjunction with a phone or a PC, but I'd like to know if it is possible to implement a software solution (on the phone) that would allow the phone (a Nokia 6630) to act as a Bluetooth headset connected to a PC. I.e. the phone would play the sounds from the PC and send sounds from the phone's mic to the PC, just like a regular Bluetooth headset.
Any ideas?
Mossy
good qestion, it sounds quite simple and should be possible. i have searched around looking for something similar. but was think more in the lines of useing my nokia 6680 as an internet phone i.e. for skype. the only thing i came up with was nokskype (usefull client) looks like it could work quite well the only problem is that you have to pay for it before u can use it. they should have given us a 15 day trial or something cos its hard to tell wether it wil do the job. it only allows calls to their server which you cant really spk to so theres no point. this software however installs a client on your mobile as well as your pc which conects your sound card via bluetooth to your mobile but only works with the skype applet. just makes me think there must be something similiar out there its just awkward thinking of the right thing to search for wht do u call it?
