Hi, I have just started playing with my Nokia 6600 by installing application which I successfully did. I installed an emulator EMame, I believe it got installed in directory called C:\MAME but I don't know and don't know how to check. This game emulator requires additional files (roms) to play the games and these files need to be placed in a directory called C:\MAME\ROMS but by using the Nokia PC Suit software I can't get to or see the C:\MAME directory which is where EMame is believed to be installed.
Can someone please tell me how I can place the Rom files in the C:\MAME\ROMS directory of the phones internal memory.
Thanks in advance
use seleq(a symbian progs 4 ur phone) or use file explorer from pc to see ur files.I usually use bluetooth connection with file explorer
shadow44 wrote:use seleq(a symbian progs 4 ur phone) or use file explorer from pc to see ur files.I usually use bluetooth connection with file explorer
Thanks for the reply.
I have setup a bluetooth connection to laptop using Belkin Bluetooth USB adaptor. When I click on "My Bluetooth Places" I see the following:
OBEX File Transfer on Nokia 6600
OBEX Object push on Nokia 6600
When I double click on "OBEX File Transfer on Nokia 6600" it is empty. So is this the "root" directory of the phone? Should I not see the application (EMame) in this folder? Is this where I should create \Mame\Roms directory? or am I doing something totally wrong?
Actually I just tried to create a new folder and it gave me a message "Incorrect Permissions". I just don't know what to do.
Thanks again
