Hai There,
can Anybody please help me out on how to open text files in nokia 6630. when i open a text file it says FExplorer! Unknown File Format..
and also my phone doesn't display messages in hindi.. it just displays small rectangle boxes.like this [] [] [] [] []
please help on both these problems..
please email me at [email][email protected][/email]
regards,
It should be on C:, E:\System\Recogs folder.
I forgot the file name but u can try to move files on that folder 1 by 1 to another folder.
About Hindi font, I think u should go to nearest NCC (Nokia Care Centre) to flash ur phone with Hindi language.
y2kamitabh wrote: can Anybody please help me out on how to open text files in nokia 6630. when i open a text file it says FExplorer! Unknown File Format..
What about if you highlight the file and use 'Options | File | Hex/text viewer'? Does that work for you?
Steve
Actually, the file is located in E:\System\Recogs\PTBoot.mdlshayanbahal wrote:
I've installed and uninstalled the thems and after that I got problems with opening .txt files..it says Unknown file format!
also I got problems with Picture Messages and I cannot save them. even I transferd them by computer to the mobile , whenever I try to open one of them it says: "Unknown file format".
I have Nokia 6600. my friend with also 6600 got this problem too... but the only difference is he still have not uninstalled the phone thems!
thanx
shayanbahal wrote:
I found out what was the problem...
this file :
was making all those problems.
Anyway thanks for your time.
hope your staff are fine
So,... occasionally we take a hammering from looking for goodies from the net. I do not hope much FREE from it, indeed.
Good luck
http://www.allaboutsymbian.com/forum//forum/thread/44613/#post253298
