Hi, i have recently bought a nokia 6680 smartphone and it was working fine untill suddenly without any warning the gallery of the phone stopped working. i can access the gallery but it shows no files in there. it is most odd because i know i have photos and music on my phone because i can access them via file manager. its weird because it shows that there is nothing in there when i know there is.
can anyone help.????
thanks for your time.
-Try safe mode with or without MMC.
-If the gallery data store in phone memory, then try to pull out ur MMC and try again with/without safe mode.
-Mostly, kind of problem like this, u've corrupted data or MMC.
More info:
http://allaboutsymbian.com/forum//forum/thread/44365/
http://www.allaboutsymbian.com/forum//forum/thread/26301/#post222494
thanks, rulirahm,
that has worked, it now shows me the origional phone sample photos, videos and music when the memory card is not in. Do you think i should delete all the data on my memory card to try to get rid of the corrupted file that is causing the problem?
-How about 'safe mode' with MMC, can u take a look for the image?
-Just try to take a look for corrupted MMC. I'm so sure that u've a corrupted MMC.
-Well, if u think that is nothing important with all of the data in ur MMC, why not ? just delete them all. If there is important data or a big file, use card reader to save (backup) it to PC 😉 That's a good way if u have many important data on MMC also many big file.
how do i look in safe mode?
i have used the pencil key etc way, but is it obvious when your in safe mode? it just looks like normal to me
Well, actually u won't c the different.
i did what u said in the link you sent me, i put the card in my mmc reader, but there was nothing that looked like it shouldnt, i even scanned it with anti-virus software and nothing was detected. it all seems to be working ok apart from showing no files in the gallery.
U browse ur card reader by '7tools' and there is no several invalid partions in red?
I think u should format ur phone and don't forget to backup important data 1st such as contacts, mail etc. If format phone won't help u, then format all (phone & MMC). If not help too, I think the problem is with the data (corrupted/bad data).
