[OS9.1] createsis fails , devcert, acs, cannot load key, wrong tagencryptionerror
3 replies · 0 views · Started 04 April 2006
finally got my devcert based on the acs cert.
But now the command
createsis sign -cert stoegerit_devcert.cer -key stoeger_it.key ...
fails with that error:
error:06078081:digital envelope routines:EVP_PKEY_get1_DSA:expecting a
dsa keyerror:0D0680A8:asn1 encoding routines:ASN1_CHECK_TLEN:wrong
tagencryption error, Cannot load stoeger_it.key.
The key file has been generated with "vs_pkcs.exe".
Any ideas?
Thanks in advance.
Tobias
www.OutBank.de
So ... the tool is "expecting a dsa key" and you have a RSA certificate/key
Use signsis.exe, it detects the key type automatically though you can
specify it in program's options
"Tobias Stoeger" <[email protected]> wrote in message
news:jS1yPpAWGHA.504@extapps30...
> Hi,
> But now the command
> error:06078081:digital envelope routines:EVP_PKEY_get1_DSA:expecting a dsa
> Any ideas?
> Thanks in advance.
> Tobias
> www.OutBank.de
WOW - you're good!
How can I send you a beer 😉
As you said, it is working with:
SignSis -cr -s ...
Thank you very much!
Br
Tobias
www.OutBank.de
Tobias Stoeger wrote:
> Escu wrote:[color=green]
>> certificate/key ...
> WOW - you're good!
> SignSis -cr -s ...
> Br[/color]
A while ago we had such kind of experiences too with the signing helper
applications. Certainly SS can make usage of such tools easier?
AMK
