Hi
i have nokia 6600 i m gettin some prob with it
every time there bocomes a message in the Outbox folder.. with any number in my contact list the msg is empty msg status is Resend at any time ( e.g 3:40Pm)
if i delete this msg then it becomes again
can any plz plz plz solve this prob..
Wirelessly posted (Nokia3230/2.0 (4.0526.2) SymbianOS/7.0s Series60/2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Hi, it seems ur set is affected by trajon virus,do u have any antivirus?
Try Calvin Stinger (freeware) 😊
Baprasanna wrote:Wirelessly posted (Nokia3230/2.0 (4.0526.2) SymbianOS/7.0s Series60/2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0)Hi, it seems ur set is affected by trajon virus,do u have any antivirus?
Plz suggest me any antivirus which is latest and can clean viruses plz
Ok,install f-secure antivirus,with virus removal tools,itz superb,itz the only antivirus which can remove any type of virus,which is found upto date..But it needs gprs to activate it... Get it at mobile.f-secure.com
