hi
is there anr procedure to set mp3 files on tone in nokia 6600 if any then plz tell or theres any software which can convert mp3 to midi format
plz tell me
Mp3 tones on 6600
The 6600 doesn't recognise mp3 format but does recognise wav format. I suggest you use a wav-mp3 convertor (convert from mp3 to wav). There are no good mp3-midi convertors. Hope this helps.
