Nokia HS-2R
5 replies · 1,458 views · Started 05 April 2006
Hi all- again! sorry 2 post twice in such a short space of time! But i have just heard about the Nokia HS-2R (probably old news to most of u!) that supposed adds fm radio capability to all compatible Nokia fones. i have just some questions. Is the N6680 compatible? If i am listening to the radio - will the fone ring through the headphones the sane way as it would with the headphones supplied with the phone? Is it still available in the UK? Is there a microphone on it so i can talk into it?
I know theres alot of questions there but if someone could amswer them it would be a great help to me.
Thanks :icon14:
misterblister wrote:Hi all- again! sorry 2 post twice in such a short space of time! But i have just heard about the Nokia HS-2R (probably old news to most of u!) that supposed adds fm radio capability to all compatible Nokia fones. i have just some questions. Is the N6680 compatible? If i am listening to the radio - will the fone ring through the headphones the sane way as it would with the headphones supplied with the phone? Is it still available in the UK? Is there a microphone on it so i can talk into it?
Thanks :icon14:
All your questions = yes
I got mine off ebay for �9 and works perfectly on my 6680 😊
hello (again) i had just posted that reply when i saw this advertised - the "Nokia HS-12W Stereo Bluetooth Headset" I think this is the same thing only using wireless bluetooth connection instead of the wired connection? Its a bit of a jump in price (www.play.com �99.99 and www.ebay.co.uk �40 [at the moment]) Ive ever used a bluetooth headset before so is there much difference in sound quality? Would it jusstify an extra �20 (or �70!)? :con?
