passthrough Internet
2 replies · 1,687 views · Started 06 April 2006
I just buy a N6670 to sustitute my faitful Sendo X, I install Avantgo, and want to sync through the PC internet connection, with the Sendo this was easy, just plug (USB or Bluetooth) and it takes the PC internet connection, but here is really an issue, since every time wants to use my GPRS connection, I use Avantgo in order to not use GPRS a lot, since you pay for... So Syncing using GPRS is expensive and in that case I prefer to browse using opera, I want to know how could I make a passthrough connection, do I need a special software??
Thanks for all the help
I don't think there's a solution for the 6670. The method that worked with the Sendo X probably works with the 6600, still, but no Nokia S60 phone released since then (because the whole PC-connectivity technology changed after the 6600).
Too bad, it was so easy to sync avantgo without any extra expense
