How these AT command set works with Cell Phone.
What are the connection requirement for that.
I am using Nokia 3100 then How can i use these command.
They usually are used from a PC, where the phone is visible as a modem (via a real or virtual serial port) to command the phone to do something. Connection requirements depend on the phone model (what it supports); main thing is for the phone to be visible as a modem, as already mentioned.
For Nokia models the AT commands supported are described on documents like these:
garg_shal wrote: I am using Nokia 3100 then How can i use these command.
