ok.. so i got it up and running.. but now when i try and select something the backround will stay teh same.. and just wont load.?it will just fade slightly and do nothing?
i erally dont know what the problem is.. it says it has 9 satellites too..
it will also sometimes sat,.,.,.
App. closed
ROUTE66
USER-EXEC 3
Try to use 'System Explorer' by Justek to know what is that error means. 😊
Wirelessly posted (NokiaN-GageQD/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Using what bluetooth gps? What firmware has your ngage got? How much device memory is used? What memory card is it on.
..or contact the developer of the app.
