Movies to A1000
6 replies · 2,812 views · Started 08 April 2006
Hello, i have some school project clips and movies i would like to have on my a1000...
but how to?
I have tried to use the motorola media studio but the trial only allows 3minuits clips and thats not enough!
So if you could help me, wright it here or ad my msn!
[email][email protected][/email]
i got the program but how to get the codec? and what is the size that i should use!
thx for fast answer btw :icon14:
If you can watch the video with Windows Media Player, you already have the codec installed. NMMC uses the same codecs.
And about the size; experiment. See what works best. If the size and detail is to high the converted clip may stutter on your phone, but then again if it's too low it'll just look blurry. You have to find a middle ground that you're satisfied with. Just remember that the A1000 isn't a speed demon. It wasn't meant to play fullframe movies in high quality 😉
naaah.... too bad... i was thinking about to connect my a1000 to the tv and watch a full lenght movie :P
no i am just kidding :P
have someone tried the winAVI to 3gp? Would that work?
What is this!!! I cant make it work?
PLZ i'm sutch a noob! How can i convert movies to my a1000?
How to use the nokia tool? How to get the codec :P
Plz help me! ^^
