Changing N70 Fonts.
5 replies · 75,056 views · Started 09 April 2006
As i had promised that i will write this forum here it is. If you would like to change your N70 Fonts to your best ones then jus read below.
f you are one of those who do not like the plain default font or if you are a �dare to be different� kind of person then this one is for you! Change the fonts to whatever you have available or whatever suits your taste. Get ready for a little facelift for your phone 😊
Some background information: Nokia N70 does not use TTF font files, instead it uses GDR file which is a compilation of all the fonts that will be used by the phone. What we will do in the following steps is select the fonts that we want to use, use an application to compile the GDR file containing those fonts and finally uploading the font to the handset. Alright, time to begin.
#1. Download and install GDR crreator Download it here. http://www.crazylittleworld.com/n70/egdrsetup.zip
#2. Run the application. Dont worry about the funny language. I will explain how to use it to make working fonts.
#3. You will see various tabs in the application. Each tab is there to set the font for a certain part of the phone. The phone preview on the left shows the part where the font belongs. Navigate till you get familiar with what is under each tab.
#4. Under each tab, click browse to select the font, set the size (defaults should work fine unless your font is too small or too big) and select whether you want just the basic character set (ASCII/Unicode) or want all the characters + symbols from that font (Symbian/Unicode). From my experience Symbian/Unicode is only needed for Text Messaging (2nd tab in the application). See the image below for descriptions on application.
Easy GDR
#5. After you�ve set the font, click the �Compile Font� button (see image below) to add the font to the GDR and have a look at �Preview Font� window to get an idea of what the font will look like on the phone.
Easy%20GDR
#6. Finally, click the �Compile to GDR� button and save the file. Name it as you please.
Easy%20GDR
#7. Now transfer the GDR file to your N70 via Bluetooth. Create a folder named �Fonts� in C:\System and copy the file from inbox to the Fonts folder (like we did with the Screensaver files above). In the end you should get this - C:\System\Fonts\<filename>.gdr
#8. Delete the GDR file from Messaging -> Inbox and restart the phone.
#9. Congratulations, you�ve just installed new fonts on your N70.
hello.i did as what u have written in changing the N70 fonts..but,after i restart my N70,the font doesn't change..why is that so?=(
