DOS for 9210 wanted
3 replies · 2,397 views · Started 22 January 2002
Hello list, does anyone know where can I download or find DOS for my 9210..? Your kind advice is highly appreciated. Thank you.
I have been searching for software on the net for the 9210 for weeks now and I havent seen any sign of dos. I dont think that dos would work as well on the 9210 as the previous 9110 did. What did you want the dos to do? I expect someone else will be able to answer this better than me. I know what it is like to wait for an answer.
Pocket DOS (I can't remeber from who) is meant to be on the way, but its been a long time.. Vapourware perhaps.
Rafe
Hmms for DOS running on the 9110, wasn't that using a 486 CPU anyway so porting to that would have been easier than to the RISC StrongARM in the 9210.
_________________
http//www.thesoundlab.co.uk<IMG SRC="http//www.soundlab.freeserve.co.uk/gfx/flipside.png" ALT="Flipside" BORDER=0></A><font size=-1>[ This Message was edited by Flipside on 2002-01-22 1242 ]</font>
