i have 2 questions:
1. how to send SMS from PC to phone Via Bluetooth?
2. how 2 erase all calender entries in one go?
i have 2 questions:
2. On the phone, in the Calendar app, select the month view, hit "Options", choose "Delete entry" and the rest should be obvious.
bonny wrote:1. how to send SMS from PC to phone Via Bluetooth?I'm not sure what you want, exactly, because your question can be interpreted in many ways.
I'll make an assumption: You want to send SMS by typing them up on your PC and sending them to people through/via your mobile phone.
If that is the correct assumption, then you can do it in many ways.
The way I use is by using Nokia PC Suite and its feature/application to send messages: http://www.nokia.com/pcsuite
Another way: If your phone shows up (is configured as) a modem to Windows, you can use Microsoft's SMS Sender app (search for "Microsoft SMS Sender" on http://www.microsoft.com).
If my assumption was incorrect, please be more specific in what you want to do.
Yeah, me too. I thought that u wanna send saved SMS from ur PC to ur phone via BT. Well, just send it and it'll goes to ur 'Messaging' directly 😉
N/A wrote:I'm not sure what you want, exactly, because your question can be interpreted in many ways.I'll make an assumption: You want to send SMS by typing them up on your PC and sending them to people through/via your mobile phone.
N/A wrote:2. On the phone, in the Calendar app, select the month view, hit "Options", choose "Delete entry" and the rest should be obvious.
Try using "Remote S60 Professional", you can remote control your mobile thru BT from your PC. You can operate "all" the features on your mobile. How ? bcos you can see the mobile screen on your PC.
