I am testing my application with the LowMem tool on the Nokia 6630. Under
normal execution, it works fine, but with LowMem, it seems to panic with a
KERN-EXEC 0.
I have located the point of the panic, the code snippet is as follows:
CPermanentFileStore* store = CPermanentFileStore::OpenLC(iFs,
iStorePath,EFileWrite|EFileShareAny );
CStreamDictionary* dictionary = CStreamDictionary::NewLC();
RStoreReadStream dictionaryStream;
dictionaryStream.OpenLC(*store, store->Root());
dictionaryStream >> *dictionary;
TStreamId dataStreamId = dictionary->At(TUid::Uid(aStreamId));
RStoreReadStream stream;
//the is the point of the panic
__UHEAP_FAILNEXT(1);
stream.OpenLC(*store, dataStreamId);
While testing on the emulator, I placed a __UHEAP_FAILNEXT as shown above,
and on doing this it gave the same panic.
Is this an issue with the API (the OpenLC() ), or am I missing something in
my code.
I need to get my application signed as soon as possible, and any help in
solving this problem will be greatly appreciated.
Thanks in advance,
Best Regards,
Jinesh.
