Need help - virus on my phone!!
2 replies · 1,092 views · Started 13 April 2006
Hello,
After istalling 3 applications "ItWasntMe.siS"; "XRT 1.00" and "Scrmate" my phone is showing "System error" messages every time I insert my MMC card.
Also when I try to press menu button little empty white box appear in left top part of the screen leaving me option to choose "Select" or "Cancel".
When I choose "Select" phone restarts and it all goes from begining.
When I try to start phone without MMC card inserted it works fine apart that I cant send SMS messages!
Any help is appreciated and thanks in advance for promt replys 😊
From my experience.. Nothing else you can do. need to format your phone memory and memory card.
to format your phone memory.
dial *#7370#
and there popups will appear ask for your permission.
press yes. and if you set the lock phone.
press your lock key setting or default = 12345
he said it happens only when he has the mmc in, so install antivirus first, then insert the mmc, it will detect the viruses and delete them, and for the sms messages, that has nothing to do with the virus, u need to input your message center number in the message settings
