SMS Example - where can I find the code?
3 replies · 1,437 views · Started 16 April 2006
In the help provided with Nokia s60 SDK (for Visual Studio 2003) there's an SMS example (called SMS Example) that is explained thoroughly.
Nonetheless, I cannot seem to be able to find the project files for this example.
Can you please tell me where I can find these (as well as other) examples' project files?
TIA.
Manish - can you please tell me where exactly in this very long page? Under which headline?
Thanks!
galos wrote:In the help provided with Nokia s60 SDK (for Visual Studio 2003) there's an SMS example (called SMS Example) that is explained thoroughly.
TIA.
hi sir
run visual studio
go to file menu
select import symbian project
locate your .mmp file
follow the wizard
enjoy programming
